Αναγνωριστικό άρθρου : 00318983 / Τελευταία τροποποίηση : 11/03/2025Εκτύπωση
    What is the difference between the UPP-110S, UPP-110HD, UPP-110HA, and UPP-110HG?
    The differences between UPP-110S, UPP-110HD, UPP-110HA, and UPP-110HG are as follows.
    Paper type: UPP-110S
    Print characteristic: TYPE I (Normal)
    Feature: Standard
    Supported models: UP-850, UP-860, UP-880, UP-890MD, UP-895, UP-895MD, UP-897MD, UP-D860, UP-D890, UP-D895, UP-D895MD, UP-D897, UP-X898MD, UP-D898MD
    Paper type: UPP-110HD
    Print characteristic: TYPE II (High Density)
    Feature: Achieving smooth gradation with high density
    Paper type: UPP-110HA
    Print characteristic: TYPE IV (High Sensitivity)
    Feature: Achieving smooth gradation between black and white with high sensitivity
    Supported models: UP-880, UP-890MD, UP-D890
    Paper type: UPP-110HG
    Print characteristic: TYPE V (High Glossy)
    Feature: Glossy photo print paper
    Supported models: UP-895, UP-895MD, UP-897MD, UP-D895, UP-D895MD, UP-D897, UP-X898MD, UP-D898MD
