Αναγνωριστικό άρθρου : 00319138 / Τελευταία τροποποίηση : 20/01/2026Εκτύπωση
    There are SLS-1A speakers that do not appear on the network
    Check the following:
    • Set up the IP address and firewall
    • With the Line-Array Speaker Manager application, you can set up a maximum of 30 SLS-1A speakers at a time. To set up 31 speakers or more, set up to 30 speakers, or use several groups for connecting to the same network.
    • Your computer and the SLS-1A speaker are not connected with an Ethernet cable. This is not required if you are connecting through a router.
    • Your computer and the SLS-1A speaker are not on the same network (they are in different IP address groups)
    • A router supporting DHCP is recommended, as it automatically assigns the IP addresses. (the SLS-1A speaker is configured to DHCP by default)
