Camera Accessibility Functions of ILX-LR1
Learn about the camera’s accessibility functions (user assistance functions)
See below for information on various operation procedures. Also refer to the camera’s Help Guide.
Screen Reader
Only some languages may be supported for this function depending on the model. This function is available only when the language set in the menu is supported by this function.
How to enable the screen reader function
Once you use the screen reader function on the initial setup screen, the screen reader function will be kept enabled after the initial setup, and you can switch on and off for the screen reader function by pressing and holding the MENU button.
The MENU button is located on the rear side of the camera, slightly above the center, and is the rightmost of three buttons in a horizontal row.
If you have not used the screen reader function on the initial setup screen, you can enable the function from the MENU.
On the MENU screen, configure the following settings:
Select
How to set the speed when reading aloud
Select
How to enable the screen reader function by pressing and holding the MENU button
Select
Enlarge Screen
On the menu screen, press the
How to enable the enlarge screen function
Select(Setup) →
Accessibility → Enlarge Screen → Enlarge Menu Scrn → On (
Button)
How to set the magnification to use for the function to enlarge the screen display.
Select
Focus Magnifier
How to enable the focus magnifier function
- Select
(Focus) → Focus Assistant → Focus Magnifier
- Press the center of the control wheel to enlarge the image and select the area you want to enlarge using top/bottom/left/right side of the control wheel.
Focus Map (Movie)
How to enable the focus map function
Select
Subject Recognition in AF
How to enable the subject recognition in AF function
- Select
(Focus) → Subject Recognition →
Subject Recog in AF → On
- Select
Recognition Target → Select a subject.
Custom function
How to enable the custom function
To assign a function to a button or dial, select
Κάντε αποδοχή των cookies του YouTube για να παρακολουθήσετε αυτό το βίντεο
Προσπελάστε τις παρακάτω προτιμήσεις σας σχετικά με τα cookies και βεβαιωθείτε ότι έχετε ενεργοποιήσει τα cookies του YouTube στην ενότητα "Λειτουργικότητα".
Δηλώστε το προϊόν σας
Μάθετε όλες τις πληροφορίες, διατηρήστε το προϊόν ενημερωμένο και απολαύστε μοναδικές προσφορές
Κοινότητα Sony
Επισκεφθείτε την Κοινότητά μας και μοιραστείτε τις εμπειρίες και τις λύσεις σας με άλλους πελάτες της Sony
Επικοινωνία με την ομάδα υποστήριξης
Επικοινωνήστε με την ομάδα υποστήριξης της Sony
Επισκευή, εγγύηση και ανταλλακτικά
Προγραμματίστε και παρακολουθήστε μια επισκευή ή, αν μπορείτε, αποφύγετέ την
