Learn about the camera’s accessibility functions (user assistance functions)
See below for information on various operation procedures. Also refer to the camera’s Help Guide.
Screen Reader
Only some languages may be supported for this function depending on the model. This function is available only when the language set in the menu is supported by this function.
How to enable the screen reader function
Select
How to set the speed when reading aloud
Select
How to set the volume when reading aloud
Select
Focus Magnifier
How to enable the focus magnifier function
- Select
(Focus) → Focus Assistant → Focus Magnifier
- Press the center of the control wheel to enlarge the image and select the area you want to enlarge using top/bottom/left/right side of the control wheel.
How to use the focus magnifier function by touch operation
On the MENU screen, configure the following settings:
- Select
(Setup) → Touch Operation → Touch Operation → On
- Select
(Setup) → Touch Operation → Shooting Screen → Shooting Screen → On
- Select
(Setup) → Touch Operation → Shooting Screen → Touch Func. in Shooting → Touch Focus
Peaking Display
How to enable the peaking function
Select
How to set the level of enhancement of in-focus areas
Select
How to set the color used to enhance in-focus areas
Select
Subject Recognition in AF
How to enable the subject recognition in AF function
- Select
(Focus) → Subject Recognition →
Subject Recog in AF → On
- Select
Recognition Target → Select a subject.
Touch Tracking
How to use the touch tracking function
- Select
- Select
- Select
(Setup) → Touch Operation → Shooting Screen → Touch Func. in Shooting → Touch Tracking
Touch Focus
How to enable the touch focus function
- Select
- Select
- Select
Touch Shutter
How to enable the touch shutter function
- Select
- Select
- Select
(Setup) → Touch Operation → Shooting Screen → Touch Func. in Shooting → Touch Shutter
Touch AE
How to enable the touch AE function
- Select
- Select
- Select
(Setup) → Touch Operation → Shooting Screen → Touch Func. in Shooting → Touch AE
Vari-angle LCD screen
Custom function
How to enable the custom function
To assign a function to a button or dial, select
Κάντε αποδοχή των cookies του YouTube για να παρακολουθήσετε αυτό το βίντεο
Προσπελάστε τις παρακάτω προτιμήσεις σας σχετικά με τα cookies και βεβαιωθείτε ότι έχετε ενεργοποιήσει τα cookies του YouTube στην ενότητα "Λειτουργικότητα".
Δηλώστε το προϊόν σας
Μάθετε όλες τις πληροφορίες, διατηρήστε το προϊόν ενημερωμένο και απολαύστε μοναδικές προσφορές
Κοινότητα Sony
Επισκεφθείτε την Κοινότητά μας και μοιραστείτε τις εμπειρίες και τις λύσεις σας με άλλους πελάτες της Sony
Επικοινωνία με την ομάδα υποστήριξης
Επικοινωνήστε με την ομάδα υποστήριξης της Sony
Επισκευή, εγγύηση και ανταλλακτικά
Προγραμματίστε και παρακολουθήστε μια επισκευή ή, αν μπορείτε, αποφύγετέ την
