Ισχύει για το μοντέλο
Αυτές οι πληροφορίες αφορούν τα παρακάτω μοντέλα:
  • RM-IP500
  1. About this Release Version
    1.1.General
    This release version is 2.50.
    Applicable model: RM-IP500
    1.2.Software version upgrade procedure
    For how to upgrade the unit software to this version, refer to the Operating Instruction Manual.
  2. Added New Functions
    Functions added in Ver. 2.50
    • The following models were added as the cameras to be operated:
          BRC-AM7
    • The maximum preset drive speed of 127 is supported for the following cameras to be operated:
          BRC-AM7
  3. Specification Changes
    Specifications changed in Ver. 2.50
    None
  4. Corrected Problems
    Problems corrected in Ver. 2.50
    None
  5. Notes on Usage
    When operating the SRG-XP1/XB25, if the CAM POWER button is used to put the
    camera in standby mode, the following buttons may blink or the parameters displayed
    on the LCD may be displayed or hidden repeatedly.
    AE Button,IRIS/GAIN/SHUTTER Button ,ASSIGN1~3 Button,The following parameters in the LCD menu
    • OPERATION
         EXPOSURE
           EX-COMP, AE LEVEL
         WHITE
           WB MODE, R. WHITE, B. WHITE
         DETAIL
           SETTING, LEVEL
         OTHER
           CIZ
    • ASSIGN4~6
          DETAIL, AE LEVEL
    • IRIS, GAIN, SHUTTER
